Power Boost software has stopped working
My Power Boost software suddenly stopped on working. And it always shows an error every time I try to launch it. The error is stating:
Power Boost
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
What could be the reason for this? I tried searching for some compatibility issue but I am sure that Power Boost is compatible with my system. Please help.
