Power Designer missing Error issue
Hi all,
I can't explain this error a lot to you. But as far as I went to its bottom, I found that some table fields are missing. Though it's giving a table missing error, you can see next to it that it says table or no view found. It means that maybe the table exists, but table field is missing and that’s why the database is not able to view the table completely for proper results to be displayed.
I understand the database issues, but yet not able to sort them out.
If anyone of you can clear this error up, then please let me know. I have attached a screenshot of the error, so you can actually see what the error is given by the system database.
I think it might be easy for someone who is familiar with using MS Access and is able to link an Access database to other databases.
Hope to hear from you soon.
Sybase Database
PowerDesigner – Error
[Sybase][ODBC Driver][.ODBC SQL Server Driver ]Table or view not found: Table ‘PMUSER’ not found
SQLSTATE = S0002
