Power & Glory V3.0 Install error
Hi!
I was trying to deploy Power & Glory version 3.0, but I faced an error during installation
#ERROR: Unpacking error, status 2
Unable to continue.
OK
I request to please help me out of this problem and suggest me a valid solution, please.
I will very thankful to you.
Answered By 30 points N/A #174032
Hi there Robert L Hammon,
Status 2 in the error you're getting stands for corrupted download. There's not much you can do to fix files that came to you already corrupted, so the only way of solving your problem is to redownload the files again. If you can see what files are corrupted, you can download only the problematic ones.
I would highly suggest you to try using mirrors to download the files instead of the original link.
Best regards,
Drake Vivian
