Power Supply Compatibility to the Parts
How do I know the power supply I am going to buy is compatible with the parts that I am going to assemble?
At present, power supply contains the multiple parts power supply cables. If you buy a power supply it will have 24 pin main power cable, 4 pin 12 volt cable, 8 pin 12 volt cable, 6 pin PCI Express power cable, 8 pin PCI Express power cable, SATA cable, 4 pin peripheral cable and floppy cable.
You can choose the cables compatible with your parts. If your computer motherboard's power supply is for 24 pin main power cable and your power supply has 20 pin main power cables, it does not matter.
You can use 20 pin main power cables instead of 24 pin main power cable. But other cases should be compatible with your parts. And all are available there. However, if you need anything more for your components you will be notified by the originator. Â
I hope you understand it.
Thanks
