mario yulia
Posted on - 04/16/2012
Hello Guys,
I wanted to ask if you have any other recommended powerful network protocol analyzer aside from Wireshark? Please specify what are their most useful features as well as common bugs or issues if you know or heard of any. Thank you.
Powerful Network Protocol Analyzer in the Market
You can mentioned about wireshark on your questions. Though it is one of the best but you want any another powerful, am I right? In this purpose, I suggest you to use Etherial. You can use it in fixing troubleshooting, analysis network or anything in the server, verious software and protocol development, and also learning oe education.
It’s most helpful features are-
1.     You can read live data from ethernet, FDDI, PPP, Token-Ring, IEEE 802.11, Classical IP over ATM, and loopback interfaces (at least on some platforms; not all of those types are supported on all platforms).
2.     You can captured network data.Â
3.     Ethereal’s editcap program help you to capture files that can be mathematically edited through it’s command line switches.
4.     You may also use softperfect network protocol analyzer. Know more about it from- https://www.softperfect.com/products/networksniffer/
