I like to play ROR 0.36.1 so I installed this game but when I tried to run an error message displayed while disturbing the screen and I can’t select anything.
This error is strange to me so I spent many hours fixing it but I can’t do anything without your help.
Please help me.
Powerpad Error
Can’t write to file descriptor 3 (error 112: there is not enough space on the disk.)
Powerpad error for ROR 0.36.1
The problem is “Can’t write to file descriptor 3 (error 112: there is not enough space on the disk.)”. The issue is pretty obvious, the file path in which ROR 0.36.1 have been installed must have a limited disk space only. To check, you have to go to the drive in which you have installed the application and check the remaining storage size.
If the storage size of the disk is less than 1GB, try to transfer the file path to another drive, if you have, that has much greater storage left than that of the current drive. You have to uninstall the application and install it in a different drive and not just copy/paste the folder. This should help.
