I recently started using PowerPivot and have successfully installed it on my Windows XP Operating System. Now I am trying to install the add-in but the cryptic pop-up message appears on the screen as you can see the attached image. I am unable to install this so waiting for an expert’s advice. Would you please help me. Thanks.
PowerPivot for Excel Setup:
1: 0: 2:
PowerPivot for Excel Setup error
Hi John,
This error while trying to install PowerPivot usually occurs due to admin rights issues on your computer. I would suggest you verify if you are the admin and have all the rights or permissions. If you are unable to install PowerPivot still, try creating a new user profile on the machine giving yourself the admin account and then proceed to install PowerPivot. You should be able to successfully install the software after these steps.
