PowerPoint 2010 showing error with Windows XP Laptop
When I was using PowerPoint 2010 on my Windows XP Laptop the image went black and the following message appeared on my desktop. After that every time I tried to open that application the same message appears. Why is this happening and how can I prevent this from happening again?
MaLDoHD for Crysis 2 v3. 0
Unhandled exception has occurred in your application. If you click
Continue, the application will ignore this error and attempt to continue. If
you click Quit, the application will close immediately.
Could not load file or assembly 'Interop.IWshRuntimeLibrary.
Version=1.0.0.0. Culture=neutral. PublicKeyToken=null' or one of its
Dependencies. The system cannot find the file specified.
Details Continue Quit
