Hi guys,
I received a message indicating serious error of my Microsoft PowerPoint 2010.
Microsoft Office 2010 is running on my Windows 7 ultimate. I clicked on Yes several times but no result.
It is frequently throwing the message.
What should I do? If you have any idea regarding the issue, please help.
Thanks in advance.
PowerPoint experienced a serious problem with the ‘articulate presenter
ribbon’ add-in. if you have seen this message multiple times, you
should disable this add-in and check if an update is available. DoÂ
you want to disable this add-in?
                                     Yes    No
PowerPoint get a serious problem with articulate presenter ribbon add-in
Hi Adam Johnson,
I have ready your concern and I am very much interested with it. I have checked forums and sites about that problem and I think I have the best solution.
Please do check this Link: PowerPoint Ribbon Add-in
It gives you a lot of information regarding with your concern.
I hope that it helps you a lot.
Thank you and more powers.
PowerPoint qualified a serious problem with 'articulate presenter ribbon' add-in. You should disable this add-in. Then check to see if an update is available. If you want to disable this add-in, then PowerPoint may attempt to disable add-ins, such as Articulate Presenter.
After that experience, a crash or else closes unexpectedly.Ensure that your presentations, audio/video, quizzes, and interactions resources are located on your local hard drive. Sometimes working on a USB drive or Network drive can cause unpredictable behavior.
There is something, just check it.
If you receive this message continue in PowerPoint, and then you have to uninstall and reinstall Microsoft Office. In addition, these steps include uninstalling and reinstalling Articulate Studio ’09, since Studio ’09 relies upon the Microsoft Office installation.
If you use Windows 7 / Vista, then Go to Start, then Control Panel, then Programs, then Programs and Features and then uninstall Articulate Studio '09.
Same as in the Programs and Features window, uninstall Microsoft Office.
Restart your computer.
Now reinstall Microsoft Office using your installation disc or executable file.
Now reinstall Articulate Studio '09.Â
If you use Windows XP, then Go to Start, then Control Panel, then Add or Remove Programs, and then uninstall Articulate Studio '09.
Same as in the Add or Remove Programs window, uninstall Microsoft Office
Now restart your computer.
Now reinstall Microsoft Office from your installation disc or executable file.
If you use Windows 2000, then Go to Start, then Settings, then Control Panel, then Add or Remove Programs, and uninstall Articulate Studio '09.
Same as in the Add or Remove Programs window, uninstall Microsoft Office.
After completing these steps, you will get rid from your problem.
