I installed Adobe Master Collection CS5 in my Mac Book Pro (OSX 10.5) that contained Premiere Pro CS5. However I am experiencing problems with the Premiere Pro CS5. The problem is that the Premiere Pro CS5 does not appear on my applications list. I tried correcting the problem by doing the following: uninstalling and reinstalling Adobe Master Collection CS5, installing Premiere Pro CS5 on its own and running Adobe Creative Suite Cleaner Tool. All this was in vain as the problem persisted. When installing Premiere Pro CS5 on its own, Bridge and Encore were also installed. At one time I had installed Premiere CS4. It however is no longer installed. Furthermore, I have since changed my hard drive. Is there anybody in this forum who has an idea what is causing my problem? What do I need to do?
Premiere Pro CS5 installation problem
The installer you might be using might be the one with problems. It may not be having all the adobe packages that you need to install on your computer, and then you might want to get another setup or get install each application separately. But before you resort to use another setup, I will suggest that you do the following:
On your computer, go to the control panel and remove all the programs installed by the adobe master collection.
Get the adobe master collection setup and run it.
During the installation steps, you should be keen and see if you come across a step that requires you to check which applications you want to install. Make sure you check all that you want.
And then see if you can after that see them in the programs list.
-Experttechyv
If you want to install Adobe Premiere Pro CS5 and you have OS X 10.5, try updating your operating system. Adobe Premiere Pro CS5 supports both Microsoft Windows and Macintosh. For Microsoft Windows, Adobe Premiere Pro CS5 supports 64-bit Windows Vista Service Pack 1 (Home Premium, Business, Ultimate, or Enterprise edition) and Windows 7. 32-bit Microsoft Windows is not supported.
It requires 64-bit Intel Core 2 Duo or equivalent AMD Phenom II or faster processor, 2 GB RAM, 10 GB free space, video card with OpenGL 2.0 support, 1280 x 900 minimum screen resolution, and sound card compatible with ASIO protocol. For QuickTime features, Adobe Premiere Pro CS5 requires QuickTime 7.6.2 or higher. For Macintosh, it supports OS X 10.5.7 Leopard and 10.6.3 Snow Leopard.
It requires multicore 64-bit Intel processor, 2 GB RAM, 10 GB free space, video card with OpenGL 2.0 support, 1280 x 900 minimum screen resolution, and sound card with Core Audio support. For QuickTime features, Adobe Premiere Pro CS5 requires QuickTime 7.6.2 or higher. If your Macintosh computer runs on OS X 10.5 Leopard, just update it to version 10.5.7 or upgrade to OS X 10.6.3 Snow Leopard.
