Prepare Forest Active Directory settings execution failed
When I start to prepare the forest of my Active Directory for Lync Server 2013 and follow the steps which worked very well for my friend, I have this error and nothing seems like to work. I did the same steps many time without a result. Does anyone have a solution for this error ? What did I missed ?
Thank you !
Prepare Forest Active Directory settings execution failed on an unrecoverable error. ForestPrepareTask execution failed on an unrecoverable error.
WARNING: Enable-CSAaForest encountered errors. Consult the log file for a detailed analysys, and ensure all errors(4) and warnings(0) are addressed before continuing.
WARNING: Detailed results can be found at “C:UsersbaluilagAppDataLocalTempEnable-CSAdForest-[2014_02_09][22_29_24].html”
