I have installed this Rhapsody app on my Samsung Android phone. This rip rhapsody downloads on android has enabled me to add tracks to my Rhapsody playlists via my PC. However, when I checked on my android phone to download the tracks, it removed 5 previously downloaded tracks from the playlist, is this normal or a bug?
Previously downloaded songs are removed by rip rhapsody downloads on android.
Hello.
Rhapsody app needs the playlist to be saved after download.
If you download the playlist and do not save it, it automatically deletes the previous list whenever a new list is added.
This is a normal thing and not a bug.
Make sure that you save the previous list whenever you add a new list.
Thank you.
Hello Daniel Nicholass,
Rhapsody is a popular android application instead of your Music Player. So, it has not been a bug.
It may be your playlist problem that when you add tracks to your Android phone, you forget to save it.
So, when you add tracks to your phone by using your Computer, you must save it. Then it may not remove your downloaded tracks.
Hope this may help you to solve the problem.
