Price Of ASUS EA-N66 Wireless Adapter
The average price of ASUS EA-N66U Wireless -N66 wireless gigabit Ethernet adapter is 99.90 Euro or $128-$130.
The ASUS EA-N66U Wireless have unique patented 3X3 antenna design which minimizes interference and provides consumers the fastest Gigabit network speeds currently available. It’s design also helps you to connect internet anywhere around the home. Users benefit from a 3-in-1 adapter, repeater, and access point design, as well as easy setup and management in a few simple steps. No disk required for install, streamlining the process.
Some of the advantages of using this wireless gigabit Ethernet adapter are :
1. Excellent performance,very unique stylish look,range is excellent
2. Dual band, very good build quality,easy effortless set up
3. Gigabit Ethernet port,light weight but sturdy construction,wall mountable.
The Asus EA-N66 Wireless Gigabit Ethernet Adapter supports 3 modes of operation:
It is a single device with 3 identities. It has a dual-band wireless network with a 450 Mbps theoretical speed. The stylish pyramid shape offers both artistic value and practical approach to technology, surrounded with orthogonally-arranged antennas to lessen interference and boost signal coverage. The Asus EA-N66 Wireless Gigabit Ethernet Adapter has the following features:
The Asus EA-N66 Wireless Gigabit Ethernet Adapter supports Linux, Mac OS X 10.3 and higher, Windows XP 32-bit and 64-bit, Windows Vista 32-bit and 64-bit, and Windows 7 32-bit and 64-bit. For more information about this device, see Dual Band Wireless-N900 Ethernet Adapter, ASUS EA-N66 ASUS-Black Diamond Series Dual-Band N900, and Asus EA-N66 Wireless Gigabit Ethernet Adapter review. The price varies from £80 to £100.
Notifications
