Price For The Replacement Batteries For Dell Laptops And Solutions Too
Hello, notify the price for the replacement batteries for dell laptops and brief for it as well and thank you for solving and reply asap too.
Hey, for replacement batteries for dell laptops can be also done form the online portals such as eBay where you can get the battery replace and will cost you approx. Rs 1800 or more as per the system you are looking for. Also it can be replaced from the dell as well if under warranty or will charge if not included n warranty too. The battery will have 4800 mAh capacity and it will be of lithium type as well.
If you are looking for a replacement battery for your Dell laptop, LaptopBatteryOne is probably the best choice. They offer high quality laptop replacement batteries for thousands of Dell laptop models. They also offer free shipping for purchases over $75. Their replacement batteries are designed for safety and compatibility that’s why you are sure you’ll be getting the best battery for your laptop.
To purchase a replacement battery, you first need to know the model number of your battery. Disconnect the battery from the battery compartment at the bottom of the laptop then from the information printed on the battery, look for its model number. Once you locate it, visit the site and look for it from the list.
Since you did not indicate the model number of your Dell laptop, here are some battery part numbers for Dell laptops:
Part number 0RD301 – Dell 0RD301 Battery (9 Cells 6600mAh 11.1V); SKU: LB-DE36-66-0RD301; compatible with D620 series, D630 series, D630C series, D631 series, D630 UMA, D630 ATG, D630 XFR, D620 ATG, and M2300. Price: $34.95, currently out of stock.
Part number 0F965N – Dell 0F965N Battery (9 Cells 7800mAh 11.1V); SKU: LB-DE47-78-0F965N; compatible with 1525, 1526, 1545, 1546, and Vostro 500. Price: $49.95, currently in stock.
