Price for the tablets with usb ports and windows 8 only.
Notify the price for the tablets with usb ports and windows 8 and the key specifications for it as well just for the understanding too and thanks for the same.
The tablets with usb ports and windows 8 will cost you more than 30k if bought from the online portals or can be purchased from its showrooms as well with some accessories as well. The same will come with a year’s warranty of the products too. Below shows the specifications of it as follows:
• It is supported by Windows 8 OS
• It supports Intel core processor with 2.0 GHz
• Has memory of 16 GB
• Minimum Ram will be up to 1 GB
• Its light weight too.
If you are looking for a tablet that runs on Microsoft Windows 8, then you should check for the Lenovo ThinkPad Tablet 2. It runs on Windows 8 powered by 1.8 GHz Intel Atom Z2760 processor and Intel Intregated HD SGX545 GFx GPU. It runs on 2 GB RAM with 64 GB internal storage.
It has Wi-Fi 802.11a/b/g/n, Bluetooth, 8-megapixel rear camera, 2.1-megapixel front-facing camera, 1 USB port, microUSB port, microphone and headphone, mini-HDMI port, and microSD expandable up to 32 GB. It measures 10.1 x 6.9 x .3 inches and weighs 1.2 pounds. Video recording is limited to 720p only. It is offered with a 1-year standard warranty for parts and labor.
For the pros, it has a long battery life, accurate pen, and a light-weight attractive design. For the cons, the tablet doesn’t come with a standard stylus and the USB port doesn’t support bus-powered hard drives or peripherals. It costs around $249.99.
Notifications
