Price of iPhone 5 In Middle East
Can any one tell me how much iPhone 5 price will be in Middle East and Gulf countries ? But I feel that iPhone 4s price was very high in my country .
Yes, you are right about the price of iPhone 4s. It was too high in the Middle East. The price was US$710. Apple iPhone 5 will be launched in Europe, US, and Hong Kong next week. The price of iPhone 5 in USA will be $199 for 16GB device, $299 for 32GB device and $399 for 64 GB device.
But the unlocked version of iPhone 5 will be sold in the Middle East and Asia region by apple and this unlocked version of iPhone 5 will be cost almost more than three times higher than locked version of iPhone 5. the prices will be $649 for 16GB device, $749 for 32GB device and $849 for 64GB device. The price of iPhone 5 is still not set yet in the Middle East but it is probably going to be as higher as $1500 for unlocked version. Hope you got your answer.
Thanks for your question.
IPhone 5 costs from 3399 from 3359 AED but it all depends on where you buy it. Prices always differs from store to store, based on my experience, its scenario always ends up a store offer cheaper prices that others, it takes much time but it’s worth it when you are in a strict budget. Also, it’s convenient to buy on a trusted online site because sometimes they offer discounts on selected items.
If you are interested in iPhone 5, here are the specifications. The Apple iPhone 5 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies. It was unveiled to the public and released on September 2012. It measures 123.8 x 58.6 x 7.6 millimeters and weighs 112 grams. It uses nano-SIM card.
It has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass with oleophobic coating. It ships with iOS 6 upgradable to iOS 10.1 powered by Apple A6 chipset, Dual Core 1.3 GHz Swift (ARM v7-based) processor, and PowerVR SGX 543MP3 (Triple Core) GPU. It doesn’t support microSD.
It runs on 1 GB DDR2 RAM with internal storage available in the following capacities: 16 GB, 32 GB, and 64 GB. The primary camera supports 8 megapixels with f/2.4, 33mm, LED flash, and autofocus featuring 1/3.2″ sensor size, 1.4 µm pixel size, face detection, touch focus, HDR (photo), geo-tagging, and panorama and can record video in 1080p at 30 fps.
The secondary camera supports 1.2 megapixels with f/2.4, 35mm and can record video in 720p at 30 fps with FaceTime over Wi-Fi or Cellular and face detection. It has 3.5-millimeter jack featuring 16-bit/44.1kHz audio and active noise cancellation with dedicated mic support; Wi-Fi 802.11 a/b/g/n with dual-band and hotspot support; Bluetooth 4.0 with A2DP and LE support; GPS with A-GPS and GLONASS support; and USB 2.0 reversible connector.
It doesn’t have FM radio. The pre-installed Safari web browser supports HTML5. Java is not supported. It runs on non-removable 5.45 Wh Li-Po 1440 mAh battery with standby time up to 225 hours both on 2G and 3G. Talk time is up to 8 hours both on 2G and 3G. It is available in black/slate and white/silver colors. It is priced at around 340 Euros at the time.
But since it has been four years since it was released, in Dubai for example, the current price is now around 637 Dirham or roughly around 163 Euros or around US$ 173. The price range differs according to storage capacity.
Notifications
