nadeemrao
Posted on - 08/04/2011
I have two sites Primary and Metro for SAN and servers. Currently I am using a Primary SAN for Server allocation and Metro SAN for Data Replication. Both sites are connected through dark fiber and FC zones are replicating, replication has stated distance between both sites is 8 KM.
I have a large vacant pool of SANÂ on Primary site and want to use it on Metro Site for server allocation like as using for Primary site servers.
My question is can I use it on Metro Site or not. If, yes then what is the additional configuration required.
asimm
Primary Storage Allocation on Metro site Servers like as locally ?
Are your Windows you use properly serial. Then it should work. You can try to browse for alternatives on your computer.
Try to use the previous system or the best thing is to remove it and download the new and latest version or install from a good source and make sure that your system supports the upgrade version.
Secondly make sure that your system supports the latest version. Another thing is that there might be some corrupt files or some virus, which is resisting the running of your program. So try to scan your computer and repair the windows and other files. Do this in normal mode or the best thing is to do it from safe mode.
For other configurations you can take help.
