doriswneil
50 points
Posted on - 05/22/2013
Hi guys. I just installed the Prime Number Checker/Calculator prime number software on my desktop. I launch the program and all I see is a black screen. What could be the problem? My desktop is on Windows 7 64 bit. Thanks in advance.
Prime number software only shows a black screen
Hello Doriswneil,
You have a problem with Prime number checker/calculator software.Have you installed it correctly and latest version which support windows 7 64 bit.You can reinstall the Prime number checker/calculator software.For this you can download this software from here Download freely.
You can also check the prime number from online.If you want to do it, you have to go this check online link.
Now enjoy it.
Thanks
Taylor
Hi Doriswneil,
"First you have to verify the exigencies of the software installed on your computer (specially the graphic card) because your problem is related to the visibility of the program.
If system requirements are OK (compatible with your PC) and the issue is still there, then try to uninstall and reinstall again the application"
Feel free to interact with us if any information needed.
Hi Doris,
    Black screen on the software can be caused by conflict with windows component or a damaged installation. Here are the things you can try:
Repair the software installation through the Control Panel.
Reregister MSXML on the computer. Follow link for detailed instruction on registering MSXML. Make sure that you do this with Administrator access.
Repair .Net on the computer to see if it is running without problems, if you would also notice the same problem with other software then it must be the .Net that is causing the problem.
If all else fails, reinstall the software and make sure you get the full package installer.
