Print spooler service stop in xp
Print spooler service stop automatically after 5 to 10 Min. I have to manually start again from services.msc but it will again stop.. please help
Here are the steps to resolve print spooler service problem.
(1) You have to remove your printer from computer.
(2) Paste below mentioned link in your browser. http://www.microsoft.com/en-us/download/details.aspx?id=17657
(3) After downloading windows resource kit tool install in you computer.
(4) Then you have to click on START menu then select ALL PROGRAM you will find windows resource kit 2003 inside.
(5) Select Command prompt power shell from the menu you will find command prompt.
(6) In command prompt type cleanspl.exe and press enter.
(7) It will ask for your computer name so you have to type it. If you don’t know then type 127.0.0.1 which same thing.
(8) Some process will be happen and you will see your spooler service restored successfully.
(9) Restart you computer and connect printer and install driver again.
After doing this your problem permanently resolved.
Here is the solution, go to the following website:
https://support.microsoft.com/ph/1173
Windows XP fix it solutions
Bullet # 7 says: “you cannot add a printer and you receive printer spooler error messages in Windows XP”
Clicking on this link takes you to the actual spooler problem list
Scroll down to the tab called “fix it for me”
To fix this problem automatically by Microsoft you have to click on the fix it box (Microsoft Fix it 50126d) and follow the instructions
This is the only solution I have found that actually works
Notifications
