I have hundreds of text messages between my father and I. He recently passed away and I would like to print out our text messages to remember him by. How can I print the text from my iPhone? Is there a good way to save them in my computer also?
Print Text Messages on iPhone?
HELLO
If you want to print your messages of iPhone then you can mail your messages. First open your text message which you want to print. Hold the message and copy it. After that open your mail application of iPhone and in section to write email address of yourself. After that paste message there. And send it, Send message you can open in personnel computer and print it through local machine.
Yes, the previous post is correct. Follow it to be able to print the text messages from your iPhone. If you want to store all the text messages you exchanged with your already passed away father, one way of doing it is to backup your phone using iTunes. When you backup your phone, it will also backup all your text messages.
Before you backup your device, make sure you are using an up-to-date version. If you haven’t updated yet, download and install iTunes 12.1 32-bit. It is compatible with Windows XP Service Pack 3, Windows Vista, Windows 7, and Windows 8. Don’t use this if you have a 64-bit operating system. 64-bit Microsoft Windows requires the 64-bit version of iTunes.
For 64-bit Microsoft Windows, download and install iTunes 12.1.0 64-bit. It requires 64-bit Windows Vista, Windows 7, and Windows 8. Microsoft Windows XP is not supported in 64-bit version. Another way of storing your text messages to your computer is by using iMazing. Aside from text messages, it can also store MMS and iMessages to your computer.
To try it, visit iMazing Message Transfer. For Windows, it supports Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 8.1. For Mac, it supports Mac OS X 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, and 10.10 Yosemite.
