peaks
Posted on - 04/07/2012
Good evening techyv.
Im not really into computer gadgets and devices so I came here to ask some help.
My printer was broken last week and Im planning to buy a new one.
I am also planning to buy a scanner but I have been wondering about this matter.
Is there a printer with a scanner on it? If yes, how much could it cost?
I would really appreciate your time. Thank you.
Printer with a Built-in Scanner
Dear Peaks,
In the olden days it was hard to find a printer with an inbuilt scanners, but with the ever evolution of IT, it is now easy to find one. I can recommend you to buy the HP Laser Jet Pro M153dnf printer. This is because it is a multipurpose printer which has an inbuilt scanner, together with a fax, a copier, and also a 35 sheet automatic document feeder. This will only cost you roughly $300 to $ 450. Please check at the Officeworks, the Megabuy, or the Adelaide Cartridge Co for your purchase. This is how it looks like;
Hello Peaks!
Buying a printer with a built in scanner is common nowadays. So if you're still looking for a solution, I've got one for you. I would like to recommend to you the HP Printsmart Ink Advantage e-All-in-One Printer – K510a. You can print as fast as 29 pages per minute and comes along with a TouchSmart Frame, and wireless connection capability (so you don't need a USB cable to connect with your desktop or laptop). It is compatible with PC and Mac. Better yet, you can have this bad boy with just $185.
This is what it looks like:
For more information, click on this URL.
