My printer is an HP LaserJet M1005 which is connected to my computer. I have some files on my Android phone which I wanted to print on my printer, but the problem is, there is no Bluetooth device on my printer that I can use to transfer files. Can I print files from my mobile phone using a data cable or is there any other simpler method to achieve this?
Printer connectivity from android phone with or without cable.
Yes you can connect your iPhone with your printer. It`s really simple. First of all you have to check what printer you are using if this printer is of Apple Company then with the help "Air print" app you can do it easily. Just by configuring your iPhone with the printer.
But if you have any other company printer then first you have to check the model of that printer and after that download the related app and simply configure it. You can get detail information from here and also visit this website too.
