Mr.AL
Posted on - 08/14/2011
I have a problem with my printer Laser Shot LBP-1120.
I print a word document in my printer but no print was done and there's an Windows error stated:
" Data Execution Prevention – Microsoft Windows
To help protect your computer, Windows has closed this program."
I tried to restart my computer and unplug my printer but nothing happens.
I also tried to restart and stop the print spooler but still the same error came up.
What should I do and what would be the possible reason why my printer didn't print anymore?
Please help.
Thanks
PRINTER ERROR : DATA EXECUTION ERROR
yes ,, this "data execution prevention" is for preventing the abnormal behavior of the program,,,when it comes all widow explorer get hang,,you cant even click anything this all had happened with me also that's why i know the solution to remove it..for it firstly you have to make your pc working atleast for to minutes,,,ie unplug the printer,,,,and then go to
control panel>system>advanced(tab)>performance settings>their you have to click on turn on the DEP(data execution program)> their you will see your printer click in front of it and restart the lapy or pc …then it will work frequently…..it will work 100% ….take care..
