Printer not being detected by computer.
My computer does not detect printer even though it is connected to the system and is receiving power from the outlet, how to resolve this problem?
Hi
Some times when we have a new hardware device and we connect it to our system the system may not detect it or give errors like, “USB device not recognizable”.
This happen when the system does not have the necessary drivers installed for the device to function properly. In recent times windows devices or updates have tried to provide drivers for most new hardware devices through the windows update feature but sometimes a new devices or very rare devices do not have compatible drivers. You can follow these steps which may help you solve this problem:
If you think your printer is working perfectly like the LED power indicator is active it’s just that it is undetectable to the operating system, I don’t think Microsoft Windows was completely unable to detect it. You probably just didn’t notice it on the system tray.
Normally, when you connect a printer to the computer using the USB cable, the operating system can detect it immediately and will pop-up a message informing you to install its driver. But there are times, no dialog box will appear. Instead, a message will pop-up on the system tray saying “USB Device not recognized”.
If you are busy with other things and you didn’t notice it, you would think that your printer was not detected. In this case, try inserting the USB cable to another USB port and verify that it is detected. If the message “USB Device not recognized” appears on the system tray, install the printer software. That should fix the issue and allow you to use your printer.
