I have a printer which is recently causing some trouble. It was printing perfectly recently and I have just added the new cartridge. The printer is showing color availability however it is not printing anymore I have tired examining ins and outs but could not find any problem. I need to print a great deal of pages every day and it is really important for me. Please help me get rid of this problem.
Bruce Norway
Printer is showing enough color but not printing
Printer’s Not Working follow Cartridge Change
Once the ink in the cartridge is ended, you moreover need to change the cartridges or obtain them refilled with ink. Whatever, the case possibly, you will have to take the cartridges out of the printer and put them back in place. Some times, you will find that the printer does not print, even though the cartridge ink is full. The problem could be sorted out by checking if the cartridges are securely in place. Secure it, and the printer is sure to start working.
And now you can use it and enjoy.
Hi
You are using new cartridge that is great. You have to used a good cartridge. I think you get a perfect cartridges. In this case your printer may content dust. So you can clean your printer by using cotton swabs and warm water etc . But if you have no experience about clean printer,please go to customer care. You can also bay a good one with chosen from Amazon join prime( https://www.internet-ink.com/support).
