Printer’s Ink Not Detected By PC
Why does my PC say that I need to refill ink when I just refilled? I have an HP color inkjet printer. No clue on the manual.
The PC often makes errors whenever you do not install a program or software properly, in your case its your ink, what you should do is try removing the cartridges and replacing them carefully, but ensure that the tape is removed, as well as your printer turned off, after you replace, and its a positive result, print a tested page.
If not, then remove the cartridges and take off printer and clean the copper cartridges using a cotton swab, leave to dry for 15 mins. and then try it ensure you hear the click from the printer. If this doesn't help, power up your printer Using the steps as on your manual. follow these steps it will work.
The ink cannot be seen on PC if it is already refilled but you can still print.
