Printing an Avi file into dvd on Mac laptop
Using mac I want to print a movie which is Avi file into Dvd what is the procedure to print avi file on Dvd and also what will happen if my laptop broke down during printing…..
Solution 1:
To encode DVD playable on standalone player you is the solution to encode with DVISION3 with XVID codec you will get a "divx" playable on standalone player or you have the solution to encode with toast7 on DVD and you then get a dvd.
Solution 2:
FfmpegX for:
"destination" tab: DVD mpeg2enc
DVD – – put 720/576 (480 NTSC puts default) PAL "video" tab
"Audio" tab, nothing touch
significant check "Decode with mplayer" replaces "Decode with QT", "options" tab
Encoder (bottom right) and it's done.
