Printing an extra blank page after each form
I've been printing several medical documents in my office, what I want to do is to print extra blank pages after each form using Linux. How do I make this happen?
You want to print a blank page after print each form. Yes, that’s possible in your Linux operating system. Here following the tips regarding that issue:
At first you should select the Tools option and then select the Option in your MS office program.
Then you should check or mark the box Print Automatically inserted blank pages.
Now open your selected file which you want to print. Then insert a blank page after each form. You need to add a blank page after each page for print blank page in your printer.
Then give the print command for start print your document.
Thanks
