Printing of Mail Merge in MS Office
I have created mail merge of one of my office document. I want to print some specific range. Please help me out to print mail merge range from 5 to 30.
I am pleased to help you regarding on your problem. At the end of this, I guarantee you that you will be able to learn how to print specific pages in mail merge. Before we move forward, I know that you are aware that in a normal document in MS-Word, printing specific pages is very simple. However, I could say that in Mail merge, it is also simple, but there are differences in the procedures on printing specific pages between normal word and mail merge. Here’s how to print specific pages in mail merge. You just need to input the page number and section number. So if you like to print page 5-30 and it is in section 3, here’s how you do it. First, in the menu, choose “File” then “Print”. You will see a page range box, so just type the range of the specific pages you want to print. Example is, p5s3-p30s3.
That’s it, hope this helps.
Thanks
