Printing: Margin, position on page
I would like to print out my pdf 1 inch from the left side of the paper. Is this possible?
Thanks, Ruth
Thanks, Ruth
Thank you so much for your response. If possible, might I request more help. I tried using Adobe Reader, going to the File menu… but I do not see "Options".
I had been trying to use Adobe Acrobat Professional. I cannot figure out how to tell it to print out a certain distance from the left edge of the paper. I don't want to "auto-rotate and center" when I print out. But if I uncheck "auto-rotate and center", it prints out wrong: The side of the document is being cut off. If I could tell it to leave 1 inch at the left edge, I would be fine. Thanks again, R
Notifications
