Printing from Metro Apps ?
How to use Metro Apps in Windows 8? How do I print any pdf file from that? Does anyone have information regarding this?
It’s quite easy and simple to print from within metro app in WP8
1. Connect your printer to the computer. No need for driver installation.
2. Select where you want to print and open a metro app Maybe Browser or Maps
3. Press CTRL+P and the connected printed device will appear
4. Specify number of copies, quality of paper , page orientation ……
5. Press “Print” button and look for the printed output in Printer Tray. That’s it.
We must mention that not all metro app support printing. For example: I was unable to print from News Apps .
For Printing in Windows 8, apart from Metro apps, the procedure remains same. I mean you can print using CTRL+P or using the File menu in other programs like we used to do in Windows 7 and XP.
