Printing problem in adobe reader from net
Hi everyone, I am facing a problem when I want to print a PDF directly from the net.
I am using adobe reader for PDF, so is there any solution for adobe reader print direct printer?
Please help me out,
Best Answer by Fraserr Dawn
Answered By 0 points N/A #174618
Hello Mellisa,
I believe that you are trying to print a PDF which is opened in a browser. The error you are getting could be the problem of your browser. If you don't want to save the file and want to print the PDF. Here is the way to do it:
1. Open the Chrome browser and go to the desired PDF file.
2. On the settings tab click on Print or use the hot key feature. Press Ctrl + P.
3. Change the settings per your requirements.
4. Click on print button.
Note that your printer must be attached to your computer as well, you might be getting errors due to your printer connections.
Try this, hopefully this will do the job.
Thanks
Answered By 0 points N/A #174617
Hi Mellisa,
If you are having problems printing documents directly from the Internet, you can save the PDF file in your PC and open it with Adobe Reader.
After that, you can easily print your document out with the default Print command in Adobe Reader. If that does not help, check the connection of your printer with your computer.
If it's all right, you can re-install either the printer driver or the Adobe Reader driver. For uninstalling, please open Computer. and select Uninstall or Change a Program. For clear details, please refer to the image.
For Installing Adobe Reader, you can download the latest version from the Adobe Reader Download Page.
Regards
