I was doing my case study and when I was about to print it, I got frustrated that I could only print a single copy at a time and I had to turn it off and on to print another one. I am using the Canon Images Class mf4270 s/cp/f. The trouble with this, is that the default setting is stuck to 2-sided printing. The field of Copy Setting default reads ''OFF'' for 2 – sided printing while the shortcut button constantly reads ''ON'', which means 2-sided printing is to be done.
I hope someone can help me out with this.
Printing problem of my printer
About the problem you're facing now, try to uninstall the software for that printer. Install it again and observe all options. Try again to print something from your computer. Accurately select the ''Printer'' when clicking file/print. Check the printer's setting by clicking the ''Properties'' button and you need to turn off the ''Duplex Printing''. Then after changing the settings, click OK.
Another thing is the kind of printer you have. Since, some of it prints automatically on both sides of the page because of the default settings of Automatic Duplex Printing, these need to be turned off manually each time a single copy print is required.
The other one is Manual Duplex Printing, where you can select the printing options. You can check where your printer belongs. Just click the manual of your printer. Choose the tabs in the dialog of print and review its options. The printer which has the support of Duplex Printing states duplex printing on both sides of the paper. I hope this helps you.
