I recently purchased a Epson Stylus SX405 WiFi Edition All In One Printer. The problem is I my computer sometimes wont start, probably from a faulty power supply, but that is not the issue. I want to print directly from my android device. Can anyone send me step by step instructions?
Printing via WiFi using android device
Smartphone has this feature that will let you print, use the phone as remote control on your TV. It'll let you use the Internet by way of using wireless connection. And if you have important files that you want to print, this type of device has that features too.
Here are the steps that will guide you step-by-step on how to print using Android devices. This is an effortless job and all you need to have is printer and of course Android smart phone that has Internet access, connects to the Wi-Fi. The first step is to configure your smartphone's wireless capability. You should have Internet access to perform all these steps. Once Internet is established then you can do the printing all you want.
You will need an application that you need to download. Do the steps below;
* Go to Android market share, Download and install the PrinterShare unto your Android tablet smart phone.
* Go to Printershare app and the Menu, select Printer and print whenever you want.
