Printshop 22 compatibility issues with Windows 7
Hello All,
I run into this error message while trying to install PrintShop 22 into my laptop using windows 7, 64 bit version. The program compatibility assistant informs me that the application requires .NET Framework 1.1 to install. Following this direction, I had the .NET framework installed on my system. Then I attempted installing the program again. But even now I get a message reporting compatibility issues between windows 7, 64 bit and Printshop 22. Now I am confused, was it only this .NET framework that is missing or am I wasting my time attempting to install incompatible software on my computer? Does anyone know if it is possible to run Printshop 22 on windows 7? Please help. If so what else could be causing this issue? Kindly let me know if there is a patch or workaround to fix this. Thanks a million to whoever helps me.
Image:
Error:
Program Compatibility assistant
This Program has known compatibility issues
Check online to see if solutions are available from the Microsoft website. If solutions are found, Windows will automatically display a website that lists steps you can take.
Program: Microsoft.NET Framework 1.1
Publisher: Microsoft
This software has known incompatibility with IIS services on this platform.
