This message appears every time I want to play Pro Evolution Soccer 2010. It says that my PC is not good enough for this game, but FIFA 10 and any other games are working just fine. This is the only game that gives me this kind of error. If I click Ignore this error appears again, if I click Retry again. Is there a solution for this? My VGA have 512MB and is not working. Thank you!
Warning:
Your computer does not meet the minimum specifications necessary to run this software.
You may experience errors during operation.
The video card does not have the necessary specification.(GPU:VRAM128MB)
Pro Evolution Soccer 2010 does not meet requirements
Hi Raymond,
You cannot install that game because the minimum requirements of a computer should be Windows XP SP3 or Windows Vista SP1 or Windows 7. The processor should be Intel Pentium 4 which has 2.6 Ghz. Has a RAM of 1.5 gb. It will cost 9 gb memory on your hard drive and has a minimum video card of GeForce 6800GT 256mb.
That is obviously a problem with the specifications of the game. This only means your computer does not meet the requirements to run the application. The error points specifically to your video card which lacks the required amount of video RAM to run the game.
Since the game requires 128 MB video RAM, that means your video card has only 64 MB video RAM which is commonly found on built-in video cards. If you want to play Pro Evolution Soccer 2010, you need to upgrade your video card. The game “Pro Evolution Soccer 2010” supports Windows XP Service Pack 3 and Windows Vista Service Pack 1 or higher.
It requires 2.4 GHz or faster Intel Pentium 4 or equivalent processor, 1 GB RAM, 8 GB free space, 4x DVD drive, Microsoft DirectX 9.0c-compatible video card with 128 MB video RAM and Pixel Shader 2.0 support, and sound card.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
