Problem while opening a standard wsl file
I received an Index was outside the range exception while I was trying to open a standard wsl file: InfragisiticStyleLibrary.wsl with the Appstylist for ASP.NET. Verify the information in the attached file.
I even uninstalled and installed the whole program but it did not change anything.
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. Index was outside the bounds of the array.
Does anyone know how to solve this problem?
I'd be very grateful if you shared it with me.
