Amy Burpee
Posted on - 08/05/2011
Hello all experts,
I am facing a serious problem, when I use my computer. When I start my computer there, it shows that error messages with a Blue Screen of Death(BSOD):
Stop 0×00000024
NTFS_FILE_SYSTEM
I can't use my computer. Please help me to solve this problem.
Problem with 0×00000024 Or NTFS_FILE_SYSTEM
This Windows stop error 0×00000024 Or NTFS_FILE_SYSTEM can occur if there is a problem in the system file Ntfs.sys.
This file is that you make your system read and write in the NTFS files.
You have to check your local disk errors so follow those steps:
Open my computer and then right click on the driver you want to check errors and click proprieties.
Click on the tools tab and then click check now
Select the following option from the check box dialog list (Automatically Fix file System Errors, Scan for and attempt recovery of bad sectors.
Click Stat button to start checking your disk
Restart your PC and problem is resolved.
I think the reason why your computer boots permanently on that blue screen is because of an error in the system drive’s file system. A possible corruption on drive C’s partition might have caused it.
If you can’t do anything and your computer already boots or starts permanently on that blue screen, might as well format the hard drive and install Windows again.
Usually, if the problem is not severe, that blue screen will disappear the next time you start the computer. In other words, a system restart usually fixes that blue screen problem.
But if you can still start the computer the next time around, try checking your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities or Norton System Works.
