Problem 1053 Error Starting Service Fixed
I need fixes for the error 1053 error starting service urgently in windows 10. People please help me with this and tell me the fix for this annoying problem. I have tried many ways like chkdsk and scanning the PC but nothing worked.
Answered By 0 points N/A #300720
To fix the problem you are facing you need to open the registry editor-
  1. Go to run in start and then type regedit and press enter
  2. Then find HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Select the folder and then right click on the right side pane a click on new DWORD value
  4. Name it as services Pipe Timeout
  5. Then modify it and then click decimal and enter 180000 and the click ok
  6. You need to restart your PC after that.
Answered By 590495 points N/A #302181
Since that error has something to do with a third-party application, try restarting your computer and see if the error appears again. That could only be a glitch during startup because Symantec products normally starts with Windows and encountering sudden errors is inevitable. If this did not work, check your computer if you have another antivirus or internet security program aside from the Symantec application.
A computer should only have one antivirus or internet security program. Since an internet security program also includes an antivirus, it is also considered an antivirus not just an internet security application. If you have more than one antivirus, you should uninstall the others. There should only be one antivirus running on a computer. If this did not work, try to uninstall and then reinstall the Symantec product.
This should fix the problem if there is a corrupt file in the program. Also, check if your computer meets the requirements of the Symantec product. Check the system requirements of the Symantec product and make sure your operating system is supported.
