Problem in 3D effects on Ubuntu.
I am using Ubuntu 11.04 v.i am running 3D effects on Ubuntu.
But i do not find teskbar and sitebar.
How to solve this problem?
It seems your desktop has been crash after you set up your wall to 3D. But don't worry, without the taskbar or sidebar, you still can run your programs from terminal. To get your terminal run, type Ctrl + Alt + T. After your terminal show up, now type this to get your sidebar and taskbar back to normal again:
OR
for best result, run this before unity –reset
Later, if you want to play with your 3D wall, better you back up your desktop setting first. in simple, use ubuntu tweak to backup desktop settings, it has Desktop Recovery settings to backup your desktop
To run Ubuntu Tweak from terminal:
