I have used action camera and it was working good. But I was trying to use an action camera as a webcam. I think it was not installed properly. There might be a problem with action camera drivers. After installing and plugging the camera it say do you want to open the file? Help me please.
Problem with 720HD action camera drivers in my computer
If your camera came up with a driver CD then install the driver of the camera from the CD. If that does not solve the problem, you can go to Device Manager in Windows and search for an update to the driver. You can access the Device Manager from the Start menu. In the search box type "Device Manager" and open the first program that comes in the list. In Device Manager, search for your device name and select "Update Driver" option from the menu at the top.Â
If that does not help, you can search for a driver on Google for your camera. Simply enter your camera's model name and add "driver" after it.Â
Hope it helps!
If you need further assistance, please contact.Â
Regards
