Jeremy Jack
30 points
Posted on - 10/19/2012
Hello experts,
A problem about security processor loader. I am using a Windows 7 starter operating system but the security processor loader is not working properly, the CPU capacity is getting slower and slower. The files that I want to access are having some problem, it crashed or not respond anymore. Tell me what to do experts.
Here are some websites that can help solve your problem with your security processor.
yaana16
10 points
Hello Jeremy,
Has the security process loader been working properly on the same operating system or you have been having problems with it since installing the OS? In case the problem started occurring lately you can try a system restore and see if that will resolve the issue.
Ya
If you installed the operating system properly then I don’t see why this problem is happening to you. If you frequently access the web, check your computer first for any sign of infection. Slow performance on computer is sometimes associated with virus infection. Update your antivirus and then run a full system scan on your entire machine.
If the scan didn’t find any infection on the system then you should try updating your Windows 7 to update the operating system’s security features and functions. If you are using a genuine or a licensed version of Windows 7 Starter Edition I’m sure you will have no problem doing the Windows Update.
