devon devon
Posted on - 02/24/2013
I am using a laptop of Acer brand and there is a download option for Acer aspire Bluetooth windows 7 drivers. But I am in a trouble because its saying Bluetooth hardware not found. My laptop is an Acer Aspire 5253-BZ661. Is there any solution? Please help me.
Problem with acer aspire Bluetooth Windows 7 drivers
hi,
i read your problem and i have some tips for you to fix that, first see the settings of your laptop maybe your Bluetooth driver is on off mode, second check your driver if it is updated and if not try to update it, or maybe it is infected by a virus, i guess only 🙂 . And to be sure check this site http://www.acer.com/worldwide/support/ for more solutions thank you!
Sometimes, although the hardware seems to be installed, it is possible that it is didn’t actually “ran”. I think the software you’ve installed encountered some problem while installing or never really completed the installing process. It is also possible that the driver you just installed is the problem. I suggest you to uninstall it and download a new updated one at Acer’s official website. Here is the link:
