anonymous
7060 points
Posted on - 07/27/2012
After i install mudbox 2013 i want to activate it ,but when i was try to open mudbox ..as for activate and the button for (try) is Off >>license status was 1.1.0 ..
I click activate button than i got this message. a license error has occurred contact your technical support representative for assistance to determine the nature of the problem the error code is : 110 really i search all the time to solve this problem.
Please i need a help
Problem with activate mudbox 2013
You may be getting that error because the license you are using is not genuine. Did you purchase that application or you downloaded it? If you downloaded then it is possible that you got Mudbox 2013 application that is not genuine. You will therefore need to do the following:
Go to websites that offer genuine downloads and download the application again.
If you purchased it then you might need to return it to the store you bought from so that they can give you an application that is working as long as you still have the warranty.
Hope this helps.
Carl
