Problem in adding emoticons to a Mac email
I just wanted to ask is the mac email compatible with smileys ? I
have a problem in adding emoticons to a mac email and I really want to use
smileys in it so please help me out here.
Hi Jaay Ferocity,
Recently I also face this kind of problem. Then I got solve from my friend.
Go to mail choose menu barà Substitutions
Then select text replacement
Then you will get set go..
Hope it will work for you.
Feel free to ask any question.
I am here, no fear
Best of luck
Thanks,
Mothy Stewartyi
Hi Jaay,
Yes it is possible to use emoticons in Mac email very easily. To do so:
First go to Edit menu of your email.
Then select Special Characters from the list.
Click Emoji.
Then double-click the emoticon that you want.
Hope this will do for you. Also you can add some HTML codes to show an image in your email.
