Problem with Adobe Flash Image publishing in gif format?
Hello Experts, I need your suggestion on my problem about adobe flash cs5. Whenever I am publishing in gif format, the resolution gets worse, more likely blurry. How do I get the gif format image of the original image? If anyone knows, please help.
Answered By 25 points N/A #172561
Hi Albert,
Here are some tips on how to sharpen your gif files using Adobe Photoshop CS5.
1)      Open the gif file using CS5
2)      Click on ‘convert to timeline animation’.
3)      Select all layers
4)      Go to the Filter menu and select ‘convert for smart filters’. This way, CS5 treats the layers as one.
5)      Go to Filter again and now select ‘Sharpen’. This will sharpen all layers at once.
6)      Save the file
