I am having a problem with the latest version of adobe flash player download. I already have adobe player on my computer and each time I turn on my pc it says that there is an update version to download. But when I try to update, it does not start to load. Please suggest me how can I get the latest version of it.
Problem of adobe flash player download
Hey Abelina Sophia
If the automatic update to flash player is not working then you should visit the website to download the update manually
Click on the following link:
https://get.adobe.com/flashplayer/
If still your flash doesn't update then you should try uninstalling Flash player from your computer and then downloading it from the same link above.
Hope this works!!
Hello Abelina Sophia,
It would be a some kind of problem but it is not very big issue. You can download your latest version of adobe flash player from its official website. This is very easy to download and install. Here is the link to download the adobe flash player
Hello Abelina,
I get that more often too but in my case the update is able to run successfully. I suspect that the update may be failing to run in your case because of the following reasons:
You are not having an active internet connection on your computer. Note that the update needs to go online to download the most recent updates and install them. So if you are not connected to the internet that process will not be possible.
If you are connected to the internet, it may be slow and therefore not strong enough to download the Flash updates needed. You will need to troubleshoot that issue if that is the case.
Hope this helps.
Carl
Reinstall your flash player.
1. Go to control panel
2. select "Uninstall a program"
3. then double click "Adobe flash player" to uninstall it.
4. Go to this site https://get.adobe.com/flashplayer/
5. download the player then install it.
If updating still happen.I suggest you check on your computer might be deepfreeze on some software that keeps this from happening, you might scan your computer your computer might have virus that prevents you from updating your flash player.
