Hello everyone,Â
I have some pdf files which I need to open with Boson Netsim. My current version of pdf reader is adobe reader x. But the problem is that I can't open the pdf files of adobe reader x with boson netsim. Each time I tried to open the files there were some error massage. I don't know how to fix this. Can anyone help me how to solve this problem?
Thanks.Â
Problem with Adobe reader x from boson netsim
Sometimes, parts of Adobe Reader crash, or another problem occurs, and the computer shows many error reports.
In this case, it cannot open a PDF file.
Sometimes, viruses can damage parts of Adobe Reader as well, so you must check for that.
The latest Adobe Reader is 11.0.02. I suggest you download the latest version to fix the problem. Download it here.
If that does not solve your problem, you can use Foxit reader, which is a freeware software. Download it here.
Wish this may help you to solve the problem.
Greetings James J Khan,
I recently had some Adobe Acrobat Reader problems and I have no idea why. It might be the problem on their end meaning they did something wrong.
What i did was that I found an alternative PDF reader namely FoxitReader. I use it even now on my PC. I'm just giving this solution as an alternative.
You can Download FoxitReader.
I hope this helps you,
Regards.
