Hi techyv,
A problem with adobe save error 23. When saving a pdf file using adobe reader I got some error 23. What does an error 23 means which is related to opening pdf files? I have fifty two pdf files in my computer and have to open and save those files in to another format.
Hoping for your help. Thanks.
Hello Jeffrey,
The main reason behind the Adobe Error 23 is the incompatibility of settings between the version of Acrobat Reader that created the PDF and the version of Acrobat Reader that is being used to view that PDF file. You can easily solve this problem by simply going to "Preferences", then go to "General" and uncheck “Save As Optimizes for Fast Web View”. Now checkout. The error is fixed.
Thank you.
Have a nice day.
