I have a problem with comodo firewall, after i installed it and rebooted my pc, a pop up appeared.
It keeps appearing every time I start my pc and also when I try to start comodo firewall.
When I checked Windows Security Center it says that comodo firewall is turned on. please help me fix it.
Comodo Internet Security Error Report
Ooops! You have just found a bug in Comodo Internet Security. It needs to close. we are sorry for the inconvenience.
Please tell us about this problem to improve our software.
We have created an error report that you can send to us. We will treat this report as confidential and anonymous.
Problem after Installing Comodo Firewall
Hi Bridgette,
Have you tried to uninstall Comodo? And delete all its components and perform a fresh installation. Check if your computer also complies with the minimum system requirements such as:
Windows Vista 32-Bit and 64-Bit
Internet Explorer Version 5.1 or higher
64MB RAM
35MB HD space for 32-bit and 55MB for 64-bit
After the installation, did you configure COMODO correctly? When the installation is done, COMODO will give you the options to select components of COMODO that you can install on your system.
Dear User,
You can fix this problem easily by re installing a fresh version of COMODO Internet Security.
When you re install make sure.
You have successfully removed the existing Comodo Internet Security.
And when you are installing it, try a different version. Perhaps the latest and newest version
Because if there were any bugs, they must be fixed in the latest version
Also make sure you do not have any other firewall systems running on your Computer.
Thank you
